Theres a traffic island near my house and it sets it off everytime, nothing more unsettling than driving along at 40 then your parking brake suddenly slamming on.Etchings said:Sorry for resurrecting an old thread but had an interesting conversation with my dealers today.
There's been a spate of rear-ended Atecas (that was what my car had been in for... rear bumper trim replacement). Apparently they're seeing a lot of these incidents due to auto-braking and have told me that SEAT are about to release a software update because it's too sensitive!
He didn't have time scales but said it was coming soon.
Tricky - but is front assist activation an error? Didn't think so - the computer logs a lot of parameters over a short time (in case of accident), but only long term storage are actual faults. That is my understanding, but I'm not an expert.takingthetrain said:Hi all,
I read this post with interest. Has the OP had any luck getting this sorted?
We have had our Ateca since March and get the scary front assist warning roughly once per week. Twice it has applied the brakes forcefully. Once when my wife was driving on a roundabout and once when I was driving past a traffic calming bollard. These were both activations when they were not necessary and could have resulted in the car behind hitting us if they were too close. We have the advance warning option set to "Late" which I believe should reduce the number of alerts. The car has gone to the dealer today, for the first time since buying it, to get the front assist checked. They've come back and told me no fault found. They said that, if the activation does trigger braking then this would be logged in the on board computer. However, they said the diagnostics did not show anything in the logs. I tried to explain that the car has applied the brakes twice, so why would these not be recorded? They simply kept on repeating that the diagnostics don't show a fault. Can anyone tell me (ideally with reference to the manual or a Seat document) if these activations should be logged? If they are not being logged when they should be then this in itself would seem to be a problem. The car is still under warranty but, as they are saying no fault found they have said I have to pay a diagnostic charge and would also have to pay if I wanted the sensor to be re-calibrated (something like £300 by VW dealer). Any advice on what I should say or do here? The dealership seems very defensive (read argumentative) when I try to discuss the problem logically with them. I am quite concerned that, as we approach winter driving conditions, if the car decides to emergency brake in icy conditions then this could result in loss of control of the vehicle. Turning off the front assist is relatively simple but would need to be done every time the key is turned.
Thanks.
I have had a problem with the ABS it started with unexplained braking. had a dealership check no fault found even with diagnostic check. Problem got worse advised by second dealer to reduce sensitivity , till they could have it in but problem got worse so couldn't use the car had breakdown truck take it in. ABS had failed damaging the discs and pads cost £2500 to repair. Fault first noted 10 days out of warranty SEAT will not help at all even though the car was not used during two lock downs so had not actually done 3 years work the mileage was 21.400. so bewareI'm now getting seriously fed up with the auto braking :x . I've already set it to its lowest setting but it still went off twice yesterday in 10 minutes. The first time I got the big red scary warning in the middle of the dash, the warning sound, but oddly no brakes. Also, oddly, nothing anywhere in sight. The second time the brakes did slam on, as usual, in a country lane but this time I couldn't see any overhanging vegetation which is the usual culprit. Nearly gave me a heart attack :shock: . I'm now getting overly conscious of it rather than having it sit in the background like ABS.
In two months it's now happened on about 9 or 10 occasions and it's only a matter of time before it causes the accident it's trying to prevent. Any advice? Should I log this as an official safety problem with SEAT HQ. I don't want to have to go through the faff of turning it off every start up because it's not as simple as pressing a button like the Stop / Start. Also, if I turn it off and I run someone down, can I ever argue that it wasn't my fault?.
