1 - 11 of 11 Posts
Small question about the fog light switch; When you pull the light switch to the first position (front fog lights) the top icon turns green. At the second position(rear fog lights) the bottom icon stays red. Is this normal or is it broken?
from memory it doesn't change on the dial but it appears on your dash as on when rear go on
my biggest bug bear on the vw group is when on autolights the side light symbol lights up when on but it doesn't change when is everything on ..... it's one of those where on a light but misty morning you can't tell what is on so I switch to manual to be sure
You glance at the satnav - if it's in night mode the lights are on..... mine seems to bang the lights on much sooner than I would, but looking at other German cars this seems common.
I don't drive with my sat nav on ..... I used to like cars where all light symbols appeared on dials and you knew exactly where you were
and in light but misty no end of people are driving with no lights ............. and I suspect most those are on auto and don't realise
It's a small detail but hopefully somebody can give it a try. It's about the two left indicators on the switch.
deleted as I was grumpy lol :lol: :lol: :lol: :lol: :lol: :lol: :lol:
I gave in and went to check my memory was correct
front goes green
rearstays red
but
symbol appears on dash for rear
Think I'm excused of the 200 metres walk to my secret parking space in the cold if Saggy has sorted it.
I always have the satnav as the default screen. I suspect if they are German cars then people have switched them off auto. I'm getting slightly concerned of the cars willingness to put the lights on even when the sun is out,
Not just VW group Saggy, my Vauxhall Mokka is the same. It does my noodle in!
don't even have the SD card yet but I do like having google maps up!!
no clue on the fog-lights though. Must be a lot of the grumps around, that was both of us yesterday :lol:
1 - 11 of 11 Posts
