Hi all, can anyone advise on the issue I have just started to experience?
I have the keyless entry system and recently the car has locked itself when I get out and close the driver's door. I haven't caught the key in any way. When I try to open it by touching the door handle, this doesn't work. Instead having to use the key to open it. Yesterday, I got out of the car to unload the boot and the car locked itself again, this time with the keys still in the car. I was 70 miles from home so I would have been stuck if not for the fact that my son was still in the car and was able to unlock from the inside.
Previously to this issue, I was also getting a problem already mentioned on the forum when the locking system seems to activate EVERY TIME I increase speed past 9 ish miles per hour ( seems to activate the locks twice each time), even though the car locked on the first instance. For this, I switched off the 'auto locking while driving' then activated it again which seemed to clear the issue.
The fact that the car is now locking itself after I get out and close the driver door is concerning.
Has anyone had the same issue? If so, any resolution tips?
