1 - 3 of 3 Posts
Hi all,
I'm new here and I've had a quick search before posting this forum for similar problems.
Does anyone know the fuse location for the radiator fan for a 2017 Seat Ateca? I've had a look at the user manual but couldn't see anything standing out.
Thanks in advance!
Hi, did you ever find the answer to this? I just had the ac regas completed following installation of a new condenser. However, the rad fan attempts to start when running the ac but can’t get going. It does this every 15 or so seconds so wondering if it’s a wiring/fuse/relay issue…
If anyone ever experiences the symptoms above then the solution is a new rad fan motor. On the 1.5tsi, the fan shroud can be removed from the top of the engine once the airbox and connected plastic housing is removed.
1 - 3 of 3 Posts
