1 - 7 of 7 Posts
Hi
What is everyone running on for normal everyday usage ie 3/4 passengers with no luggage.
I just checked the panel on the car and it seem to suggest 36 psi for both front and back.
Dangermouse said:
Hi
Yep that's what I run with. Worth checking as mine were over inflated to 41 when I got it and didn't realise for a couple of weeks :roll:
Thank you Kindness will check today. Have you set up the tyre pressure monitor yet?
Yeah set it as soon as I put it to the correct pressure. :)
I haven't done anything with my tyre pressure indicator since collecting my car.
Do I need to set it up or something, as I can remember seeing an option for it as I flicked through the menus?
Does the vehicle display the actual tyre pressures or just notify you if you have a puncture?
You need to set the tyres to the correct pressure first then go into the Vehicle status and click next to access tyre pressure monitoring system. You then need to press the set button to store the current pressures. It does not tell you the pressure, just warns if it drops.
1 - 7 of 7 Posts
