1 - 3 of 3 Posts
I don't drive around with my air conditioning on all of the time, however I've noticed that warm air comes out of the vents even when the system is turned off.
I only normally have the temperature set to somewhere between 18 and 20, however the temperature of the air coming out of the vents is much warmer! If I turn on the system, leave it a minute until cooler air appears and then turn it off it seems to stop the warm air!
Does anyone else experience this and do you know how it can be stopped?
Climate control is designed to be on continuously. It uses the AC only when needed. I am on my third SEAT with Climatronic and have never switched them off ever in 17 years.
Noticed the same, I switch on the air recirc only and that stops it
1 - 3 of 3 Posts
