Leon - yes, locking nuts should be standard! However it is likely that these are supplied along with the key by dealers before delivery; I don't think they're fitted at the factory mainly because wheels can be fitted by robot which tightens all four bolts simultaneously, and aren't suited to using a different locking bolt as each car comes down the line. If I was a betting man, your dealership forgot to install; go back and ask for them. Tell is correct that the locking key is in the foam carrier under the boot floorLeon said:Can anyone confirm whether the alloy wheels are fitted with a wheel locking nut on each wheel, as standard? If not, I need to order a set. Much appreciated.
Keep an eye on the caps, Kindness, as per earlier threads they have a tendency to go unexpectedly AWOL ! Glad you think your nuts are present, if undercover :lol:Kindness71 said:I haven't checked my nuts so to speakas they have the caps on and didn't want to fiddle with them :shock: Under the boot cover however next to the spare I found my locking wheel nut key so guess I must have them fitted
Always a good idea to check your nuts, fellas.Kindness71 said:I haven't checked my nuts so to speakas they have the caps on and didn't want to fiddle with them :shock: Under the boot cover however next to the spare I found my locking wheel nut key so guess I must have them fitted
Check my specs? I don't wear them, I can read perfectly well. :lol:trogette said:Rightly so. Y'all need to check your moobs/pecs also.
