Auto handbrake sticking
fabbers
Re: Auto handbrake sticking
Post by fabbers » Thu Apr 13, 2017 8:14 pm
Hi folks, had this all day today, would set off and disengage only on second go with decent revs. Also was informed that it had gone for a wander in works car park today all on its own and rolled backwards in to another car :o
Will keep an eye on it must not have engaged the handbrake and not noticed when i got out.
jimbrimble
Post by jimbrimble » Fri Apr 14, 2017 12:39 am
I'm not the only one!
Although I should point out that I am not actually taking pleasure in you having the same issue. On the plus side it really does seem to have worked itself out now.
Ateca Xcellence, 1.4TSi, Lava Blue, too poor to get any options...
Collected from dealer on April 8th. Have been hooning around in it ever since.
Rae9911
Post by Rae9911 » Fri Dec 07, 2018 11:53 am
Hi
Yes we have the same problem and also when trying to reverse took it back to the garage 3 times on the third time told that seat does not have a remedy for the fault as yet ?
Ordered Ateca SE Technology 2.0 TDI 4drive 150PS, Privacy Glass, Reverse Camera, Convenience Pack & Towbar pre-installation with hook.
Ordered 27/04/2018.
Build Week 24
Delivery: 18/07/2018
fabbers
Post by fabbers » Fri Dec 07, 2018 4:51 pm
Mine kept sticking consistently for a a couple of days after I got it but cleared itself, so fingers crossed.
Rae9911
Post by Rae9911 » Wed Dec 12, 2018 4:26 pm
There is an issue with the Auto Handbrake sticking and SEAT UK know all about it as well.
My issues started in September when the brakes where binding and the hand brake was not releasing when the clutch was being released. So 17/9/18 it went into SEAT Blade to be looked at for hot brakes and hand brake not releasing, no fault found.
25/10/18 the car was back at SEAT Blade as the brakes were still binding and the car was struggling to pull away whether forwards or reversing and the hand break was not disengaging. I also raised the issue that the car would lurch forward when the hand brake finally released and was worried it was going to cause an me an accident. They said a fault was found with the auto hold so they did a new software update on the car.
19/11/18 car brakes and hand brake are playing up again as the hand brake not releasing. I also sent the dealership 8 dash cam clips of where I was trying to pull away and the car would not move. The dealership had my car for 3 days and the sales man admitted that after driving my car for 1 hour he had had enough of the auto hold issue and that there was definitely something wrong with my car.
The kicker in the teeth is that he said that as they have already completed the software update on my car to correct the issue there is no other fix currently available for my car and that the only option until a solution is available is to drive around with the auto hold switched off. I did not pay all this money for a car that I cannot use all the functions on . The salesman did tell me that there is an issue with the SEAT Leon & Ateca with the auto hold but the software update should have fixed it. Apparently I am one of 7 Ateca's in the UK with the auto hold issue.
04/12/18 at lunchtime I got in the car to go back to work and I tried 3 times to get the car started and could not get the car to start. It was cranking but not starting up, so on the 4th attempt I actually videoed myself starting the car and it would not start again, I let go of the key and it stayed in the start position with the engine cranking. So I phoned SEAT Assistance and they sent the AA out, I showed the AA man the video clip and he tried the car and it started. So he followed me to the garage and my car is currently at the dealership.
I am now so sick and fed up with this car and I only picked it up 18 July 2018 and its been in the garage 4 times. Has anyone else have these issues?
Ordered 27/04/2018.
Build Week 24
Post by Fred99 » Wed Dec 12, 2018 4:53 pm
I have had no issues, but then I never use autohold and only ever apply the hand brake manually. To be fair, that's all you need to do on a DSG.
