Clock
Clock
Has anyone else experienced the clock re-setting itself back to GMT from BST? I’ve had a few occasions when I’ve turned the ignition on and the clock is an hour slow.
My solution has been to reset the clock source from GPS to manual and back again to GPS but that’s a bit of a pain in the a**e and not something to be done when driving. Any ideas folks ?
Ateca 2.0 TDi 190 Xcellence DSG 4Drive Sunroof, Black.
Re: Clock
'AlasdairMac wrote: ↑Sun Jun 03, 2018 5:33 pmHas anyone else experienced the clock re-setting itself back to GMT from BST? I’ve had a few occasions when I’ve turned the ignition on and the clock is an hour slow.My solution has been to reset the clock source from GPS to manual and back again to GPS but that’s a bit of a pain in the a**e and not something to be done when driving. Any ideas folks ?
Keep it on manual.
This comes up time and time again (pun intended). Household clocks, smart watches and especially those atomic clocks you can buy that claim to be accurate within a second over 1000 years - if it gets it's information from the wrong satellite then you're knackered.
