Electric tailgate opening problem
Re: Electric tailgate opening problem
Sorry guys, no simple solution ... it turned out to be a faulty tailgate motor, had it replaced under warranty.
ATECA Xcellence 1.4 ECoTSi Petrol, Manual, Reflex Silver, Park Assist, Top view camera, Electric Tailgate with Virtual Pedal & Keyless Entry.
Bit of a bump, but I had this tonight. I put some MucOff Bike Lubricant (https://www.wiggle.co.uk/muc-off-mo94-m ... 5360719716) into the two black struts and that solved it. It must've been either the cold spell, me cleaning the car, or the salt water from the previous owners (by the sea!) that had got in and caused friction, and then that made the electronics think there was too much resistance and it must be hitting something. Sprayed in, and worked straight away.
Ha... good job!mike3105 wrote: ↑Wed Apr 07, 2021 10:12 pmBit of a bump, but I had this tonight. I put some MucOff Bike Lubricant (https://www.wiggle.co.uk/muc-off-mo94-m ... 5360719716) into the two black struts and that solved it. It must've been either the cold spell, me cleaning the car, or the salt water from the previous owners (by the sea!) that had got in and caused friction, and then that made the electronics think there was too much resistance and it must be hitting something. Sprayed in, and worked straight away.
I had the same issue with the handle on my double glazed windows at home. Completely siezed up, so bought a new one and was about to replace it when my dad just sprayed some WD40 on it and hey presto!!
2021 Black Magic Xperience Lux 2.0 TSI 4 Drive - Ordered 8/12/20 (Week 50) - Built 6/4/21 - Est Del. 17/5/21
I have a similar issue with the powered boot (tailgate) on my 2016 Ateca. When opening the boot it opened just over halfway before stopping prematurely. When trying to close the boot, via the button on the boot it didn't move and just sounded the three beeps. In the end I had to shut the boot manually. Now the boot will unlock, but not move, close and lock, but there is no movement from the motors.
Having looked at the vehicle faults, it is showing the following:
Just wondering if anyone can help, before I get the MucOff out
S
Code: Select all
Hall sensor in motor 2 for test hatch Open circuit/short circuit to B+
S
2016 ATECA First Edition 1.6 Diesel, Manual
Have you tried Mike3105's solution? He applied some lubricant (I'd imagine WD40 would be similar) to the black struts and that did the trick (see two posts above)salvogarbo wrote: ↑Sat Apr 10, 2021 11:38 amI have a similar issue with the powered boot (tailgate) on my 2016 Ateca. When opening the boot it opened just over halfway before stopping prematurely. When trying to close the boot, via the button on the boot it didn't move and just sounded the three beeps. In the end I had to shut the boot manually. Now the boot will unlock, but not move, close and lock, but there is no movement from the motors.
Having looked at the vehicle faults, it is showing the following:Just wondering if anyone can help, before I get the MucOff outCode: Select all
S
Hi, I've the same problem tailgate opens about 6 inches and stops gets 3 bleeps, having to manually lift up, sometimes closes from this height or again close manually. I've plugged in carista and getting two faults come up. Any ideas ???
