After start/stop engine doesnt turn on
Sdenizgenc
Post by Sdenizgenc » Tue Mar 31, 2020 1:06 pm
Basically, at the lights when stopped and start/stop turns off the engine when it goes to re-ignite it sounds like it is and for a split second it does and then turns off and says start engine manually. And after 20 goes of retrying to start engine it works in the end..
2019 ateca xcellence lux
Anyone else have these issues?
PSC21
Re: After start/stop engine doesnt turn on
Post by PSC21 » Tue Mar 31, 2020 2:56 pm
Low battery voltage? I`ve had several VAG cars with start stop and when they played up it was battery voltage , though system should detect this and disable s/s
FRS Velvet Red. Collected 17/1/20 Replacing 2018 Tiguan SEL Bitdi 4motion DSG , Replaced 2017 Leon Cupra.
Chop
Post by Chop » Wed Apr 01, 2020 10:05 pm
Apparently the AGM batteries fitted to Start Stop enabled cars do not like the temperatures usually experienced under the bonnet of a modern vehicles. This may explain why these batteries are not lasting long.
