Drive mode defaults to Normal at engine switch on
I have a 2019 2.0 Petrol Excellence Lux 4Drive automatic, which I have owned since new. Using the rotary dial near the gear selector, I can choose "Eco", "Normal" or "Sport" mode, as well as the 4wd terrain programs. I noticed recently though that if I use the dial to select either "Sport" or "Eco" mode, then when I turn the engine off, the next time I start the engine the car defaults to back to "Normal" mode, regardless of what the dial is set to. As soon as I move the dial, the corresponding mode is selected correctly, but again, that is forgotten the next time I turn off the engine.
Has anybody else seen this issue? Say, for the sake of argument, I wanted to leave the car permanently in "Sport" mode, if I set the dial to sport, the next time I start the engine it will default to "Normal" mode, until I remember to move the dial the dial again, even though the dial shows the LED indicator at the sport mode. When I start the engine, the digital dash shows the gear selected as "D1", "D2" etc. until I move the dial again.
My car is going in for it's 2 year service in a couple of months, and I can live with the issue until then, but I'd be interested to know if anyone else has had this issue and if it was resolved successfully?
Cheers,
Paul
Cheers,
Paul
Re: Drive mode defaults to Normal at engine switch on
Hi
In the 1.5 Tsi manual the drive mode automatically reverts back to the normal mode after the engine is switched off and started again regardless of what mode the dial is in, if you want sports mode you need to reselect it each start up.
I don’t believe it is a fault, it’s just the way it is , I am not aware if there is anything in the settings whereby you could lock in the sports mode
When you start the car.
- Paul.Cambs
I believe it does this to qualify for the emmisions the car is quoted for, perhaps in the past it stayed in the slected mode till the regulations tightened
It’s yet another emissions issue. To conform to the stated mpg etc it has to be the default.
Not much you can do about it and I have not seen an OBD11 or Carista hack to change it.
Thanks for the response gents. I understand the rationale you are giving, but it just seems a bit odd that the dial remembers it's last state when the car is defaulting to normal mode. Not the end of the world, in the grand scheme of things though.
Cheers,
Paul
Cheers,
Paul
It's not really a case of the dial having a memory..... it's just much easier and cheaper to have the software revert the car to normal than to also fit a motor in the dial to turn it back tooiPaul wrote: ↑Tue Mar 09, 2021 9:04 amThanks for the response gents. I understand the rationale you are giving, but it just seems a bit odd that the dial remembers it's last state when the car is defaulting to normal mode. Not the end of the world, in the grand scheme of things though.
Cheers,
Paul
2021 Black Magic Xperience Lux 2.0 TSI 4 Drive - Ordered 8/12/20 (Week 50) - Built 6/4/21 - Est Del. 17/5/21
Hi Johnny B,
No motor would be required. There is an LED for every stop on the dial position, so all it would take would be for the software at start up to illuminate the LED opposite "Normal", rather than remembering the last position selected, so it is consistent with the default driving mode. In my 2019 car, the dial selector rotates freely so I'm guessing that it's just the relative movement the dial mechanism is sensing, not the absolute position of the dial. I would have no issue with the car defaulting to "Normal" mode, as long as the tell tale LED on the dial also indicates "Normal" rather than kidding me I'm in "Sport" or "Eco" mode, based on what was active when I last turned off the engine.
Anyway, not worth losing sleep over in the grand scheme of things, but a minor annoyance, to me anyway. Don't get me started on the undersized cup holders though...
Cheers,
Paul
Cheers,
Paul
The cupholders are not undersized. Your cups are too big
Touché, Tony. Good point, well made
Out of interest, just how many drivers drive in anything other than normal mode?
