Haldex and DSG oil change
Hi
Could anyone please tell me what are manufacturers requirements for 4drive haldex and DQ380 7speed DSG oil and filter change interval. Quite many thoughts on Briskoda ranging from lifetime=no change needed ending with 60k-120k km interval.
My 2.0tsi Ateca is about to pass the 59000 km mark and thought I should give a look into this topic.
Thanks
Thanks
Re: Haldex and DSG oil change
I think the gearbox service is at 60k
I am not sure about the haldex
MY19 Ateca FR 1.5Tsi DSG Velvet red, Digital cockpit, Beats audio, Winter pack, Leather, adaptive cruise, Electric boot, Kessy, Lane assist, Connectivity box, Alarm, Kessy, Rear view Camera.
You'd need to check with SEAT in your country.
I looked on the UK website and it doesn't state intervals. On our Tiguan, VW UK say 40,000 miles for the DSG oil change and 3yrs regardless of mileage for the Haldex. However apparently the dealers don't routinely replace the DSG filter and on the Haldex there's metal gauze screen whoch is part of the pump that should be cleaned - again the dealers don't do that, they just drain and replace the oil.
Ateca SE-L 1.0TSi - Sept 18 - daughter's
Tiguan Match 2.0TDi 4Motion DSG - Sept 15 - wife's
Thinking about something with 7 seats to replace my old Mercedes C270CDi Estate
My old Yeti had its Haldex oil changed at 30,000 miles. Seems reasonable to me considering the stresses involved.
2.0 TSI Xcellence in Rhodium Grey, 2020 spec, spare wheel and panoramic roof.
I have the 7 speed DSG - I do believe from the workshop manual that the Haldex oil is changed at 40,000m and DSG oil at 72,000m (120,000km). I also understand that the haldex requires no work to the filter, however perhaps later, say at 80-100,000m it may be wise to clean out the mesh filter. I also believe the DSG filter is long life, so changing it at a later date may again be a wise option!
Ateca 2.0 TDI Xcellence DGS 4WD 19" Alloys Pan Roof
The dealers have been in contact about changing my DSG and haldex, it has only done 37,500m, so I raised the issue of the mileage (they say 40,000m) in the workshop manual, without a response so far! An important question is raised; how can the owner know for sure that the oil has been changed, especially if it was not required at that earlier stage?
When I bought ours in September - (2017 xcellence 190 tdi) i asked salesman if it was fully serviced at point of sale and he said it was. That was essentially true, but turns out it's due in 21 days, so I've had 6 months out of it. He said all information is held online these days, so I'd no reason to doubt him, but I found a paper copy of service record in the glove box which shows an oil service and inspection carried out in March 2020, but the haldex box wasn't ticked, although the intervals for change I believe are 3 yearly, with dsg 4 yearly or 40k miles. I'm not going to use the dealer, but instead get all oils changed at a friends garage (vag guy). Car has just turned 28.5k miles. I'm a firm believer in regular oil changes based on age as well as mileage. I normally do servicing myself, but as it needs the ECU reset I'll leave it to the professionals - well ones I can trust to do it correctly.
Pete
Pete
Coming from 2 Audis, bothe DSG and one Haldae... DSG is 38000 miles. Haldex every 3 years. Use a good VAG group independent, not a main dealer. I'm fortunate to have a good local choice, and one even ponies up to get onto the VAG database so can keep the electronic service record up to date.
Coming from 2 Audis, both DSG and one Haldex... DSG is 38000 miles. Haldex every 3 years. Use a good VAG group independent, not a main dealer. I'm fortunate to have a good local choice, and one even ponies up to get onto the VAG database so can keep the electronic service record up to date.
