Thanks bedlam. Me too, updated to 1115, using your instructions.
Regards Malcolm
Ateca 1.0 TSI black magic.
Regards Malcolm
Are others seeing "dual" speed limits i.e. 60 and 50 on their maps?
Yes - seeing this on our Ateca too - and on the Leon with traffic sign recognition, it shows only a single limit but these don't match the roads either (e.g. 60mph on dual carriageways).....
Xcellence 1.4Tsi DSG, Rodium, SEAT sound (inc. Spare!), 19" "Exclusive" alloys, double boot floor
Order: 12/03/2017 Prov build : was Wk19, then 21 Built: Wk 20
Landed : Sheerness 6/6 Danube Highway
Arr Dealer : 13/6 Collected : 17/6
I can only assume someone at VAG has messed up and that the "dual" display refers to towing and non towing limits and/or in some countries raining or not raining limits.
I have tried all 3 variants that include UK, they all do it
Just been out for a short run on a Motorway (A1M) and no speed limit sign displayed at all
Updated mine as per the guide and no issues at all
On another matter; do the units receive software updates like new features or design changes?
No, it is just the Map dataChillCupra wrote: ↑Thu Dec 06, 2018 10:06 amOn another matter; do the units receive software updates like new features or design changes?
Thanks for this tip Bedlam. Had just updated my sat nav from 0915 to 1115 which the car didn't recognise when I put the SD card back, copied the OVERALL.NDS file from my 0915 backup and now it works!Bedlam wrote: ↑Sat Nov 10, 2018 6:14 pmYou need to do everything you did earlier then copy from your backup this file
MAPS/EEC/EEC_WLD/OVERALL.NDS to your SD card.
You might want to backup your updated card to a new file too, I keep a copy of every update (just in case)
BTW the maps are due another update quite soon, what version are you updating to?
1030 is the current version.
Odd bug this one, and much appreciated that you've solved this and shared it.
Didn't previously have any issues when upgrading from 0730 to 0915 so must be a recent update issue.
Ateca Xcellence 1.6TDI - Nevada White + space saver spare + heated windscreen
I hit the same problem with updating from 1030 to 1115 and didn't manage to work around it.
I tried copying OVERALL.NDS from my 1030 install and from my original install but none of that worked. Finally after few hours of time wasting I managed to reinstate my 1030 version. I wonder if something changed in the install procedure just to make our life harder? Has anybody else managed to successfully upgrade to 1115?
Xcellence 2.0 tdi 4drive, Nevada white, 19" Exclusive alloys, top cam, seat sound, pano roof, navi system, styling kit Blue Connect,
