dash cam
STOGGY
dash cam
Post by STOGGY » Tue Jan 22, 2019 11:20 pm
Hi just Picked up my Ateca xellence tdi, well impressed so far (need a degree to read the handbook ) lol. I need some advice please I have a transcend dash cam that i had in my previous car ( Peugeot 3008 ) I now want to install into my Ateca, i want to run the power lead tucked into my headling and same again tucked down the drivers side windscreen and across under the steering wheel. I wonder has anyone done this, on my peugeot it was easy but the Ateca is a better build quality and the plastic and headliner are made of stronger material.
TIA Phil
Ghiggz
Re: dash cam
Post by Ghiggz » Wed Jan 23, 2019 7:40 am
yes a few on here inc myself have, there are a few threads already if you search the forum...
found a few...
viewtopic.php?f=9&t=357
viewtopic.php?f=8&t=438&p=5024#p5024
Silver Ateca SE 1.6tdi
shent
Re: dash cam
Post by shent » Wed Jan 23, 2019 9:01 pm
I too have just picked up a Ateca and after some searching on here had a go at fitting a hard wire for the dash cam. It took about 20 min in total very easy to do, I ran the wire along the head liner, down the 'A' post then there's a gap under the glove box that hides the wires great. But to be fair about 1HR figuring out how to drop the glove box to access the fuse box the day before without the fear of breaking it LOL. I connected the earth to the torx screw just below the fuses and piggy backed the blue 15 AMP rear wiper fuse.
viewtopic.php?t=706
You can see the Torx screw and the blue 15amp fuse clearly in the tread first picture. :D
Hope this helps in some small way .
Ateca MY19 Nevada white excellence Lux 1.5 TSI EVO 150 PS DSG
Smiffy
Re: dash cam
Post by Smiffy » Fri Jul 05, 2019 3:44 pm
There's a hardwiring kit available with the Nextbase range - comes complete with the piggy-back thingy for the rear wiper fuse.
vectra
Contact:
Re: dash cam
Post by vectra » Sat Jul 13, 2019 1:28 pm
I will be installing my dashcam to my Ateca when it arrives,
Fuse 15 ( rear wiper ) appears to be the switched fuse of choice,
Can someone advise my of fuse size size so I can order a Piggyback holder for the install?
Micro?
Mini?
Normal?
Geewis
Re: dash cam
Post by Geewis » Mon Dec 02, 2019 9:43 pm
That blue 15 amp fuse is that the one you can piggyback from, could you show in a picture. I have no probs getting to the fuse box but not sure what fuse to use.
SEAT ATECA 2.0 TDI SE TECHNOLOGY [EZ] 5DR DSG 4DRIVE Geewis357 Alias:The Black Angel®™ :evil:
Yanhow1
Re: dash cam
Post by Yanhow1 » Tue Dec 03, 2019 11:29 am
I’ve done this with my nextbase cam,
I pulled the windscreen pillar cover off, threaded a piece of wire down the side of the dash where the roof lights etc wires go down to the fuse box, it came out behind the fuse box, ( a bit of wiggling and patience is required )
I then pulled the hard wire lead back up through the dash with the wire,
Cable tied it up to the headlining and tucked it behind the lining along to the mirror.
I used the lower yellow fuse which is the 12v socket fuse and piggybacked that with the fuse supplied ( standard size ).
I earthed on the torx bolt just below the fuse box and cable tied all the excess wires together and tucked in to the right of the fuse box.
The windscreen pillar cover is popped of by using quite a lot of force pulling towards the off side pillar, ie along the screen.
Hope this helps.
Ordered 29/7, lava blue X lux 2.0TDI 150ps DSG 4Drive, b/w39.
EricM
Re: dash cam
Post by EricM » Tue Dec 03, 2019 5:10 pm
I don't know about needing a degree to read the handbook, but you certainly need good eyesight.
I asked SEAT UK to provide a download A4 sized horizontal pdf. No can do.
Eric
ATECA 1.5 TSI EVO XCLNCE EZ DSG, Magic Black, Power Tailgate, Spare Wheel, Personal Reg, Thinkware F800 Front & Rear Dashcam
nitrous
Re: dash cam
Post by nitrous » Tue Dec 03, 2019 5:26 pm
Eric
Hi Eric, You can download a copy and other info from: https://www.seat.co.uk/owners/your-seat/manuals-offline.html
That would scale up nicely on screen to whatever size you like, and you could print individual pages out (eg fuse map on page 101-103).
Cheers
SEAT Direct Parts
Contact:
Re: dash cam
Post by SEAT Direct Parts » Wed Dec 04, 2019 11:38 am
Hi all,
Just in case anyone needs help we have the hard wire kit and cabers
https://www.seat.fish-bros-parts.co.uk/?s=dash+camera&post_type=product
Cheers
Genuine SEAT Parts & Accessories at Trade Prices
All shipped direct to your door.
Get in touch today!
http://seatdirectparts.co.uk
