Ateca Sat Nav Maps
EricM
Ateca Sat Nav Maps
Post by EricM » Fri Aug 23, 2019 3:07 pm
Have just discovered that my March 2019 Built to Order ATECA XL, is supplied with SatNav software that is two years old, and that no updates are currently available.
Apparently an upgraded version was available to me at ordering, but not mentioned.
Can it be retro-fitted?
EM
ATECA 1.5 TSI EVO XCLNCE EZ DSG, Magic Black, Power Tailgate, Spare Wheel, Personal Reg, Thinkware F800 Front & Rear Dashcam
Bedlam
Re: Ateca Sat Nav Maps
Post by Bedlam » Fri Aug 23, 2019 3:43 pm
Which unit is fitted "Navi" or "Navi Plus"?
Which Map Software Version is Installed?
Max2090
Post by Max2090 » Fri Aug 23, 2019 4:39 pm
Take the sd card out of the unit in the glove box, making sure the engine is off, as the version number is written on it.
Unfortunately Seat charge for updates unlike any other VW group car. They are only up to V7 at present whereas VW are up to V11!
2019 1.6 Diesel SE Technology manual in metallic white.
EricM
Post by EricM » Fri Aug 23, 2019 4:49 pm
The version information is: 6P0719866AF; 1030; Shield 2016-44 (Build 309)
Does this help?
EM
EricM
Post by EricM » Fri Aug 23, 2019 4:50 pm
The version fitted is the standard one that comes with the car.
EM
Bedlam
Post by Bedlam » Fri Aug 23, 2019 5:33 pm
Eric the good news is you can update, here is how:
1. Download the latest uk map - http://vw-mapscdn.tdd.adacorcdn.com/DiscoverMedia2_EU_AS_1310_V11.7z and extract the data to a PC folder using 7Zip (Google this to download it)
2. On the infotainment go to settings, safely remove, sd1 card
3. Remove sd1 card from glove box slot
4. Long press on the on/off to reboot Infotainment a couple of times
5. Insert sd card in to laptop/PC
6. Copy and paste all contents to laptop/PC and retain the data forever as a Backup (preferably in two places/drives)
7. Format the SD card, keep it as fat32 and leave format settings as default in file explorer (don't forget to push the card lock mechanism to off)
8. Copy the new downloaded map version to the SD card
9. Replace /maps/EEC/EEC_WLD/OVERALL.NDS on the SD CARD with the one from the original SD card (See step 6 above)
10. Edit (using Notepad) the /maps/00/nds/dbinfo.txt file so that PartNumber4 correctly has my own part number in it, that is I replaced PartNumber4 from PartNumber4="5F...." to PartNumber4="6P0919866AF" In your case (it may differ for others, also it is only an optional step but I do it for completeness)
11. Using windows file explorer, eject the sd card and safely remove the sd card from the laptop/PC
12. Repeat Step 4 above
13. Insert the card into the card 1 slot in glove box whilst infotainment is off
14. Power on and go to navigation
15. Check version in infotainment
EricM
Post by EricM » Fri Aug 23, 2019 8:22 pm
Thank you. I will try that over the weekend.
EM
Bobbytoad
Post by Bobbytoad » Fri Aug 23, 2019 11:21 pm
Does this work on other Seat models?
Bedlam
Post by Bedlam » Sat Aug 24, 2019 2:12 am
Yes if you have the "Navi" unit
Ateca_newbie
Post by Ateca_newbie » Sat Aug 24, 2019 10:38 am
Thanks for the tip above Bedlam.
Did as explained ..... all steps apart from amending the txt file....don’t know what that does.
Maps work and I now have the latest version.......at least I hope so....all seems to be working!
I’ve had my Ateca since last October and the sd card was v7.
Ateca 1.0 SE L, Rhodium grey, :D
