Has anyone had any issues with connecting to the Seat connect app and via the infotainment screen too? I've entered my VIN but it's not recognised. It's a facelift Ateca. Thanks
Connected mine with no problem . Only issue I have it keeps removing the protection from my profile and also randomly ask for pin to be inputted on startup even though I check box to remember pin.
Still won't work without a valid VIN - and mine isn't recognised. It's a 2019 car, so I think they should have had a reasonable amount of time to add it to the database.
You can't do2 key method until your car is registered on the seat connect app as they are linked. Being a 2019 model I didn't think they were supported as new system was only brought out as part of the facelift
I too used the 2 key method but first time I did, the app wasn't functional and couldn't connect to the car. I simply redone the pairing process and all works now. If im honest its not worth the fuss. The user manual talks about being able to pre-heat the cabin/defrost etc but none of these features are on the app and when I contacted SEAT customer service they said this wasn't available on the Ateca even though it is mentioned in the manual. In addition, the locking/unlocking feature doesn't work unless unlocked by a SEAT service department and you need to book the car in for this to be done. The only thing I can do is put my hazards on or put the horn and hazards on at the same time with the app. The driving data stuff isnt much use to myself.
Seat Facelift.
Does anyone have to enter their S Pin every time your start up? I try to save my S Pin but it seems to make no difference. Does the S Pin protect the user profile?
Any help appreciated
Seat Facelift.
9.2" Infotainment system
To become a main user and thus prove ownership of the vehicle, you need both of the vehicle's physical keys. Ownership accreditation takes place in the vehicle during registration or, if you already have a SEAT CONNECT user account, you must log in through the infotainment system and then go to Manage users
● Switch on the ignition and the infotainment system.
● In the infotainment system, register in SEAT CONNECT.
● Or: open the menu Manage users > Settings > Become primary user and follow the instructions.
● Press the unlock button on the first vehicle key.
● Press the unlock button on the second vehicle key.
9.2 Infotainment system on Facelift
The system is always asking for my S Pin number every time I start the engine. It does not save the 4 digit code despite ticking the save box. Is this correct?
Related Threads
Seat Ateca SUV Forum
50.3K posts
5.9K members
Since 2015
