Hidden/Discovered Gems
Kindness71
Contact:
Re: Hidden/Discovered Gems
Post by Kindness71 » Sat Feb 25, 2017 11:03 am
Tell wrote:
Sat Feb 25, 2017 10:47 am
That's it Kindness and the price I recall was about £120 or so. A bit pricey. The other thing is and I could be wrong, you may have to take the seat out to fit it. Pretty sure the seat would have to come out. There is an advantage in not having it on the passenger side that you can get more right under the seat. That's where my second car blanket goes given the space limit in the boot of the 4Drive. Now that could be a hidden or discovered gem. Use that blanket to cover footwell stuff up when on holiday with the car. Your boxes of wine do fit nicely under the seats and in the footwell, cap it with the blanket.
Yeah reading further down that thread looks like it's not something you could not do yourself and very expensive.
Ateca Xcellence 1.4 TSI, Samoa Orange on order (11th August), Build week (52), Picked up (22nd Jan) 18", Heated Windscreen, Seat sound system, Electric Tailgate with Virtual Pedal, Double floor
Tell
Post by Tell » Sat Feb 25, 2017 11:21 am
(Pressed back more than once... but now the low down and a Seat diagram at the bottom... plenty of hidden gems)
That's it Kindness and the price I recall was about 120 euros or so. A bit pricey. The other thing is and I could be wrong, you may have to take the seat out to fit it. Pretty sure the seat would have to come out. There is an advantage in not having it on the passenger side that you can get more right under the seat. That's where my second car blanket goes given the space limit in the boot of the 4Drive. Now that could be a hidden or discovered gem. Use that blanket to cover footwell stuff up when on holiday with the car. Your boxes of wine do fit nicely under the seats and in the footwell, cap it with the blanket.
This is the parts site which doesn't as yet list the Ateca.... think this is all part of the Ateca parts problem
http://www.oemepc.com/seat
This is a parts Ateca site that I have posted up before
http://nemiga.com/cat_spares/etka/seat/at/893/9/
Woopy... last time I looked my VIN wasn't in it, there might be an elapse time but now it's showing all my parts
The front seat draw is a QN2
Seems to be the same an an Ibiza, bolted from underneath
http://www.amcarparts.co.uk/ibiza-st-ib ... ber-28264/
Left is a QN1 which brought me back to this when a Swedish member of the board posted their parts list in September :)
viewtopic.php?f=7&t=190&start=10
I'm built with this by comparison
0A2 4 doors
0AG Front stabilizer
0B1 Wheelbase
0BE Rear stabilizer
0F5 Fuel system for diesel engine
0FA Standard manufacturing sequence
0IJ Installation differentiation for transmission "DQ381" -- vehicle components --
0K0 Without alternative drive system
0N4 4-link rear suspension
0P1 Rear side exhaust tailpipe
0SC Labels/plates in English
0TA Without floor mats
0VF Information kit in English
0Y1 Standard climatic zones
0YE Weight range 5 installation control only, no requirement forecast
0Z4 SEAT marque-specific/class-specific features
1AT Electronic stability control (ESC)
1D0 Without trailer hitch
1DG Nameplate set "TDI"
1E9 Without activated carbon canister with SCR
1EX Special identification plate for EC for M1 passenger vehicle
1G9 Space-saving spare wheel for temporary use, radial tire (5-hole)
1KE Disk brakes in rear
1L1 Air cleaner for dusty regions
1N3 Speed-related variable steering assist (Servotronic)
1NL Trims for alloy wheels
1PE Wheel bolts with anti-theft protection (unlockable)
1Q3 Mass damper for steering wheel, XX Hz
1S1 Tool kit and jack
1SA Without additional front underbody guard
1T0 Without first aid kit and warning triangle
1U8 Without folding table on front seat backrest
1W0 Without refrigerator/glove compartment cooling system
1X1 Four wheel drive
1Y3 Electronic differential lock XDS dynamic traction control
1Z0 Initial standard fuel filling
1ZA Disk brakes in front
20A Without electric motor ( hybrid )
2A0 Without delivery equipment
2B2 Additional exterior noise suppression
2G5 Filler neck module 1 without insert
2H5 Driving Profile Selection and conventional shock absorber
2JD Sports bumpers
2PK Leather-wrapped multifunction sports steering wheel w/ tiptronic
2V5 Fresh air intake system with combination filter
2WA Without additional tires
3B4 Child seat anchor for child seat system ISOFIX
3C7 3-point seat belt for center rear seat
3CA Without partition
3FU Big roof system
3GE Raised rear cargo area
3H0 Without backrest release for front seats
3L3 Manual height adjustment for front seats
3LJ Door and side trim panel in foam film, insert in leatherette
3NU Rear seat bench unsplit, backrest split folding with center armrest
3QC 3-point seat belts in front
3S1 Bright roof rails
3T2 Three rear head restraints
3U1 Folding trunk cover
3ZB 3-point seat belts, outer rear with ECE label
4A3 Seat heater for front seats separately controlled
4E6 Sensor-controlled luggage compartment opener
4F2 Central locking system "Keyless Entry"
4GX Windshield in heat-insulating glass, heated
4KF Side windows in heat-insulating glass, from B-pillar and rear window dark tinted
4L6 Breakaway interior rearview mirror, auto-dimming
4N2 Standard dashboard
4P6 Rear floor panel module, type 7
4R4 Power windows with comfort operation and circuit breaker
4SD Vanity mirror, left, illuminated
4TM Right vanity mirror illuminated with cover and pocket
4U5 Luggage pockets on backrest
4UP Driver and front passenger airbag with knee airbag and front passenger airbag deactivation
4X3 Side airbag in front, with curtain airbag
4ZB Bright moldings
5A7 Comfort trunk lining with service lid/ cover
5C0 Without special body measures
5D1 Carrier frequency 433.92 MHz-434.42 Mhz
5K7 Transport protection film (minimum protection) with additional transport protection measures
5N4 Folding grab handles, multi-piece
5RQ Right exterior mirror, convex
5SJ Left exterior mirror, convex
5ZF Front head restraints
6A0 Without fire extinguisher
6E3 Center armrest in front
6EE Additional body cover on wheel arch and side sill
6FH Exterior mirror housings painted
6K4 Forward collision warning incl. autonomous emergency braking, for adaptive cruise control "high"
6PB Without hand brake lever handle
6Q2 Leather gearshift knob/handle
6T5 Interior light in footwell in front and rear
6XP Exterior mirrors, power-folding, power-adjustable, separately heated
77S Data storage device, integrated without Mapcare
79F Lane keeping system, traffic jam assist, rear traffic alert, blind spot monitor, and emergency assist
7AS Anti-theft alarm system, interior monitoring, backup horn, and towing protection
7B0 Without socket
7E0 Without heat accumulator/auxiliary heater
7K1 Direct tire pressure monitoring system
7L6 Start/stop system with regenerative braking
7LI Vehicle class differentiation -5FP-
7M3 Scuff plates in door apertures
7MM Emission standard EU6 plus
7N0 Without overhead storage compartment
7P4 Manually adjustable lumbar support in front seats
7UG Navigation system - High
7W0 Without extended safety system
7X5 Park assist
8G1 High-beam control
8GV Alternator 180 A
8IT LED headlamps
8K3 Separate daytime running lights with automatic headlamp activation and Coming Home feature
8M1 Rear window wiper and washer system with intermittent control
8N6 Windshield wiper intermittent control with light/rain sensor
8Q3 Automatic headlight range adjustment dynamic (self-adjusting while driving)
8S4 Two reading lights in front, two in rear
8SK LED tail lamp assembly
8T8 Adaptive cruise control (with "follow-to-stop") and speed limiter
8TB Rear fog lamp
8W1 Washer fluid level indicator
8WH Front fog lamp and cornering lamp
8X1 Headlamp washer system
8Y1 Two-tone horn
8Z5 Not hot country
8ZH Antenna for AM/FM reception, "diversity"
9AK Climatronic with impact pressure control, CFC-free
9D0 Without preparation for two-way radio installation
9IE Mobile phone interface with WLAN (BT interface)
9JA Non-smoker's package
9M0 Without auxiliary heater/fuel-fired parking heater
9P5 Visual and acoustic seat belt reminder, electric contact
9S6 Multi-function display/on-board computer "Colour"
9T1 Heated washer nozzles in front
9TA Without additional warning lights
9U1 Brake pad wear indicator
9VD Speaker (active)
9WT MirrorLink
9Z0 Operating voltage 12 V
A64 Category 4
A8H Top sports equipment
AV0 Driving on the left
B09 Type approval country Great Britain and Northern Ireland
B0N Component parts set, complying with vehicle type for Great Britain, various parts
C03 Operating permit, alteration
DE5 4-cyl. turbo diesel engine 2.0 l/140 kW (4V) TDI common rail base engine is TD1/TR1/T5S/T6F
E0A No special edition
EA0 Without follow-on warranty
EF1 ECO function
EL0 Without online service
EM1 Driver alert system
ER1 Regional code " ECE " for radio
ES0 Without vehicle inlet
EV0 Without charging cable
F0A No special purpose vehicle, standard equipment
FA0 Control of series production
FC0 Without customized installation
FM0 Basic equipment variant
G01 Shock absorption in front
G1D 7-speed automatic transmission for four-wheel drive
GM1 Standard electronic engine sound
I79 Tires 225/45 R19 92W low rolling resistance
I8H High radio (Gen2)
J2D Battery 380 A (68 Ah)
KA6 With front and rear view camera system and two side cameras
KK3 Refrigerant R1234yf
L04 Suspension range 04 installation control only, no requirement forecast
L0R Right-hand drive
N1B Seat trim covers in leather
PCT Area View (incl.rear view camera system)
PDW "Advanced Comfort & Security Pack 2": Lane Assist, Traffic Jam Assist, Blind Spot Monitor, and Emergency Assist
PG6 18-inch spare wheel as temporary spare tire
PHE Sensor-controlled luggage comp. opener Easy Open (incl.keyless locking+startingsystem Keyless Access w/
PK2 Park Assist
PTC Tilting panoramic sunroof, electric
PUU 19-inch alloy wheels
PW2 Heated windshield
PZ3 Maps (only available in combination withnavigation system "PLUS")
Q2J Comfort seats in front
QG1 Service interval prolongation
QH1 Voice control
QI6 Service indicator 30 000 km or 2 years ( variable )
QJ1 Chrome package
QK1 With multifunction camera
QN2 Drawer under right front seat
QQ9 Interior ambient lighting, type 2
QR9 With dynamic road sign display
QV3 Digital radio reception
TR1 4-cylinder diesel engine 2.0 l unit 04L.A
U40 Alloy wheels 8J x 19
U5B Instrument cluster, mph speedometer -Great Britain-
UC7 Rear shock absorption, suspension with increased ride height
UG1 Hill start assist
UH2 Parking brake
UI2 Electric interface for external use AUX-IN jack and 2 x USB
UK3 Mechanical rear seat release
V0A Tires without specification of tire brand
VF0 Standard pedal cluster
VL3 Extended and proactive pedestrian protection
ZN2 Navigation system "Plus"
mike22
Post by mike22 » Sun Feb 26, 2017 4:00 pm
While I have been waiting for my Ateca to arrive I have watched nearly all videos on Youtube so there were no many suprises but what I really like for example is that the steering wheel unlocks itself when the start button is pushed. I also like the engine - 1.4tsi. As a owner of Leon 1.8tsi I am surprised that the 1.4 tsi engine looks as strong as the 1.8 tsi but I have a feeling the dsg makes it look more powerful.
Seat Ateca Xcellence 1.4tsi DSG 4drive, Nevada white, 19", el. adjustable brown leather seats, pano roof, el. tailgate, navi system, assist. packet 3
MGDisco
Post by MGDisco » Mon Mar 27, 2017 8:17 am
Resurrecting this topic since I've found out a couple of things on the Ateca that I think are quite nice / interesting:
1. The light/mirror combination on the sun visors - if you have the cover slid open, the light is only on when you have the visor aligned to be able to see your face. It switches the light off if you pull it closed as you might expect, but also if you push it forwards - which is the nice bit! Not seen that in other cars before. So there are 2 ways to switch of the light - sliding the cover or push/pull the visor.
2. If you have the rear camera fitted, it has a little nub on the housing - and this scooshes the lens when you activate the rear wash wiper, giving it a bit of a clean! Only seen this applied to higher end cars so did not expect it on the Ateca!
If anybody else has found / discovered good bits about the Ateca that they would like to share, this is the thread to help others 'discover' them.
Thanks,
Mike
Xcellence 190 DSG 4 drive, Lava Blue with standard 18" (Performance), Navigation System Plus Pack, XCELLENCE Pack, Heated Windscreen, Advanced Comfort & Driving Plus Pack
Anteca
Post by Anteca » Mon Mar 27, 2017 8:23 am
Thanks,
Mike
Thanks, Mike. Nice to see the thread resurrected! Still loving just about all aspects of my Ateca. Wasn't aware of these gems!
Bila White 1.4 Xcellence with spare wheel.
Tet70
Post by Tet70 » Mon Mar 27, 2017 8:24 am
I had that on my Golf MK6 about 8 years ago. So not particulary new feature on VW cars.
MGDisco
Post by MGDisco » Mon Mar 27, 2017 8:35 am
Hi Tet70,
I've only had one other VW group car (Skoda Citigo) and it didn't have a visor light (not even a cover on the mirror) so this is the 1st car that I've experienced pushing the visor forward to switch off the light.
Previous cars from German manufacturers didn't have this feature either.... hence why I posted it here.
MGDisco
Post by MGDisco » Tue Mar 28, 2017 9:24 am
Just been looking at the 'Shoddy or Expected' thread - Jamesiow posted this:
jamesiow wrote:
Mon Mar 27, 2017 8:02 pm
If you look inside the front door bins, you will find that past the reachable parts there's space for a pocket umbrella, which tucks away into the door.... You would never guess the Ateca is built in same factory as the Skoda Superb would you?
Need to check this when I get home later on!
Post by tobydog » Tue Mar 28, 2017 9:46 am
I used to have a 2004 Audi A3 that came with the full 'lights' pack. That had the lights in the visor even back then but it wasn't standard. Although the light came on when the mirror screen was pulled back, it only did it when the visor was in the correct position. It managed this by having the electrical contacts in the visor hinge so that contact was made at the right point. Simple but effective.
It's interesting that the Audi had the 2.0 FSI engine which pumped out the same BHP and torque as the 1.4TSI does now. The 1.4 engine was a big draw for me because the Audi had superb in-gear performance and the 1.4 felt very similar (on the test drives anyway - still waiting for my one!)
jamesiow
Post by jamesiow » Tue Mar 28, 2017 9:48 am
Unless you fill that gap with something i think the likes of a pen knife tool will slip down into that gap and be hard to get out!
ATECA SE 1.0 Technology, Petrol, Manual, Samoa Orange, Park Assist, Convenience Pack, Top view camera with rear view camera, Electric Tailgate with Virtual Pedal, Keyless Entry & Rear Sunblinds.
