Just had my Ateca to my dealer for it's second year service. It's covered 12k miles. During the pre-service inspection, I was advised that there is excessive pitting and rust on the inside edge of the front brake discs, in the gap between the brake pad and the edge of the disc. They said they would need to be checked again in about three months and quoted ÂŁ294 to renew the discs. I would argue if these discs really need replacing after two years then the material they are made of must be sub-standard. Incidentally, brakes discs are not covered by warranty.
Has anyone else experienced this issue?
I checked the discs myself when I returned home and, yes, they are marked, but nothing unusual from my experience. I have seen discs in much worse condition and significantly grooved after thousands of miles, without attracting attention or failing an MOT. I can see the Ateca failing it's first MOT if I take it back to the same Dealer!
