61 - 80 of 194 Posts
Are others seeing "dual" speed limits i.e. 60 and 50 on their maps?
Yes - seeing this on our Ateca too - and on the Leon with traffic sign recognition, it shows only a single limit but these don't match the roads either (e.g. 60mph on dual carriageways).....
I can only assume someone at VAG has messed up and that the "dual" display refers to towing and non towing limits and/or in some countries raining or not raining limits.
I have tried all 3 variants that include UK, they all do it
Just been out for a short run on a Motorway (A1M) and no speed limit sign displayed at all
ChillCupra said:
On another matter; do the units receive software updates like new features or design changes?
No, it is just the Map data
Bedlam said:
You need to do everything you did earlier then copy from your backup this file
MAPS/EEC/EEC_WLD/OVERALL.NDS to your SD card.
You might want to backup your updated card to a new file too, I keep a copy of every update (just in case)
BTW the maps are due another update quite soon, what version are you updating to?
1030 is the current version.
Thanks for this tip Bedlam. Had just updated my sat nav from 0915 to 1115 which the car didn't recognise when I put the SD card back, copied the OVERALL.NDS file from my 0915 backup and now it works!
Odd bug this one, and much appreciated that you've solved this and shared it.
Didn't previously have any issues when upgrading from 0730 to 0915 so must be a recent update issue.
I hit the same problem with updating from 1030 to 1115 and didn't manage to work around it. :( I tried copying OVERALL.NDS from my 1030 install and from my original install but none of that worked. Finally after few hours of time wasting I managed to reinstate my 1030 version. I wonder if something changed in the install procedure just to make our life harder? Has anybody else managed to successfully upgrade to 1115?
Had no problem upgrading from 1030 to 1115 last week. Just took the original NDS file from my original 0730 maps and worked first time. In fact usually it takes a while when launching a new map whilst the unit recognises the new file, but this time just came straight up with the map. I was a bit concerned it mightened have worked so checked the map file and it confirmed it was 1115.
PS I used the recent newer Euro Bundle 1 update from the VW site which includes most of Europe.
Thanks for confirming. I'll have another go. I was using same maps from VW site, link posed on the forum her. I might be doing something wrong, no reason not to work just for me.
I've also successfully updated 2 days ago to the new bundle 1 version 1115. just copied the old OVERALL.NDS
I have a Seat Arona with maps version 0820:
Hardware: H41
Software: 0462
0820
ECE1 2017/18
SHIELD: 2016-44 (build 309)
I read in this forum that I can use the updated map from Seat (I downloaded "1115_MP181-1266.xEUR_DL1.zip"), but I can also download the map from volkswagen, which is more updated ("DiscoverMedia2_EU_DL2_1120_V10.7z"), unzip it in my original SD card and then copy back in the SD card the original file "OVERALL.NDS" previously backed up.
Can you please confirm these procedures, and that I can go with the more updated map from volkswagen?
Also, there is no way to use another SD card, I must use the original one right?
Thanks a lot for your help!
Thanks to all the posts on this thread, was putting off updating the maps. Had previously downloaded it from Seat site. I backed up the map data from the card, deleted the map data files on the card and then copied the new map data files on to the card and hey presto it worked. Much to my surprise.
I allways download from VW tiguan...
works fine.
Just to report back I managed to successfully upgrade my maps at the end. Not sure what first went wrong but I must made a mistake somewhere.
davon said:
This upgrade from www.seat.com is always free of charge or only once, or...? Thak you
The map files at www.seat.com are free but are never the latest available, e.g. version 1115 has been re-issued and is currently not the latest on Seat website, the latest is available on the VW website
